Thread: 2 questions
Old 08-11-2017, 02:13 PM
Default Re: 2 questions
No. Your psi is whatever your relief valve is set to. Smaller piping & fittings will just restrict flow to create slower speed of cyl movement.
Want more power, use bigger bore cyls, more surface piston area. Soft flexible rubber hyd hose, don't exceed 20bar. Stiffer neoprene hyd hose might be good to 40bar.
