Old 10-14-2017, 02:17 AM
Default 1972 AMC Matador - Police
This is a 1972 AMC Matador sedan black & white 'Adam 12'.
Originally built by Cox as a gas powered free run car with interchangable steering cams that made it drive patterns.
Stripped chassis
She may not be the new Bluesmobile, but i think it's going to work out ok. Missing 2 headlight lenses, and a lightbar lens. I think i can work aound that...
I wasn't around when these were, so i'm going to need some help on lighting patterns. I grew up mostly with CrownVics with a red/blue lightbar up to the current lumen-wars nightblindness causing dangerous walls of light.
Headlights, tail lights, marker lights are easy. May even do turnsignals.
Roof lights do i want wig-wag or both on independant flashers?
Do i want headlight high beams to wigwag opposite roof, or were they not doing that yet?
Do i want tail lights to wigwag, or was that not happening yet either?
Powering the back is my one issue i haven't figured out. Original axle is plastic 1/4" hex between the wheels, and had a huge tooth spiralcut gear
