Old 10-23-2017, 04:54 AM
frizzen frizzen is online now
Default Re: 1972 AMC Matador - Police
Gentlemen, i have exhausted the swear words i know. I need to learn more languages...
Let's back up to how i could have gotten what actually worked 'the easy way'. I pulled the lens out, turned the lens pin mount into a through-hole, then up sized it to fit a 3mm Led with the flange filed off. Then one side got up-sized again to about 2/3 or 3/4 depth so it's past the next hole we drill. I drilled a 0.028" hole up through the base intersecting the through hole for leds, then passed 3 strands of 0.005 magnet wire in tiny hole base, and used a stick to push wire out the big side of through hole. Then scrape some enamel and tim end of wire, attach, test, install, test.
Red has the oversize holes, not too awful, but looks like i'll probably need to do a lens
