Old 12-28-2017, 11:05 PM
A quick question for those of you with a tad more experience building then I have.........If I were to use BRASS tubing, & ALUMINUM round stock inserted inside of it, will standard lead/tin solder work to adhere the 2 together. I'm looking to make joints to secure 2 pieces of brass tubing together. My thought was to insert 6mm alum stock into the brass tubing, so that it aligns as near perfectly as possible. I'm having trouble finding brass tubing that's the size I want, AND at the same time lengthy enough for what I want to do.
