Old 01-24-2018, 11:26 PM
Originally Posted by Northern Farmer View Post
That’s a bummer. Atleast you have the correct ESC ordered now. Did you have a chance to install your new track motors on the 4200 ?
This is what the problem was with the 4200
4200 drive sprocket parts by Anthony Kalnoski, on Flickr
Those are the pins that keep the drive sprocket connected to the motors. I started to replace the motors today. I found that (I was fairly warned this may happen) the motor mounts needs the motor hole enlarged to fit the upgrade motors. I spent over an hour with the Dremmel tool trying to do one side of it. I only got about half way done with it. I realized I needed help. Having heard the owner of the LHS talking about a guy they know that does custom machine work fir them, I called them. I dropped off the motor mounts so they can resize the motor holes fir me. HOPEFULLY they get er did faster then the 3-4 weeks I was quoted
