Old 02-28-2018, 06:56 PM
mavrick0 mavrick0 is offline
mavrick0 is on a distinguished road
Default Re: Extending the battery leads
It's about the same. All depends on your setup. If you'd rather keep the battery, esc, reciever all in the same general area I'd extend the motor wires. Or what you could do is put a connector on the motor side of the ESC then add the length you need to the motor to reach the ESC with the right connector on it.
