Old 03-07-2018, 12:11 PM
Table Top Trucker Table Top Trucker is offline
Table Top Trucker is on a distinguished road
Default Re: Lesu Liebherr 574 loader kit build
scotty k: I heated the pinion with a heat gun and put the motor in the fridge. I slipped the hot pinion on the cold shaft and got an interference fit. I need to contact Lesu and get the specs of the pinion.
Lil Giant: the metal parts are aluminum, unfortunately no bushing at the pivot point. I find it weird that they did this considering they used flanged bearings for the axle pivot !!
once the pivots wear out I will drill them out and put in flanged bearings.
