Old 07-24-2018, 06:25 PM
Default Re: newbie needing help with connecting 4 motors t one channel
That plan would work.
But i'd look up the specs (stall amps) on the motors, then find a single ESC that has greater amp capacity than the 4 motors. Wire motors in PARALLEL.
If it's an articulated chassis that bends in middle to steer, you need 2 esc, different wiring layout, and channel mixing.
