Old 09-11-2018, 09:56 PM
Default Re: Hostile's projects and various
That looks like a fun project.
For the drum rotation why not reuse the stock drive gears, stick the pinion on a small slow gearmotor driven off either a cheap esc, or hacked servo board. If you use a standard size servo board the max speed could be set with resistors
I saw a couple other builds where they used a short driveshaft mounted to a nipple coming off the big end to connect motor. I think the drums were strapped in with several bearings mounted as rollers.
