Old 01-20-2011, 03:12 PM
SmallHaul's Avatar
Default Re: New "SmallHaul" Youtube channel
Originally Posted by Claus View Post
Nice Scott. I watched the video of you loading the Mack with the dragline, you have a lot of patience. That Mack goes through anything, even when the wheels aren't on the ground it plow through.
Thanks, The rear suspension is completely stock and the front probably has almost twice the movement of the rear (not too much:-). It is hard to get it stuck though because the rear most axle is locked and the other 2 act like limited slip diffs because of my rubber washer mod to the diffs.
Originally Posted by D8R View Post
Nice vid, Thanks for sharing
Mack is a Bruder I guess, but what chassi under?
Dan
The chassis is KH frame rails cut down and all of the axles are tamiya semis with a tlt axle in the front.
Stock KH frame rails before shortening.
Build thread for Mack:
http://rctruckandconstruction.com/sh...ack+dump+truck
Scott
"No load is too Small"
