Old 12-31-2019, 08:58 AM
Default Re: CAT 14M3 Motor Grader
So how did you mark the hoses so you know which two pair together?
Good question, and I'm glad that I was thinking that when I mounted the hoses to the brackets. Basically I drew a map of the bracket and marked which hose is in which hole, and I kept the same order all the way. There's 14 lines in 3 layers on the brackets, so it could be quite of a mess
