Old 02-02-2020, 03:23 PM
Default Re: Newbie Scratch Build - D575A Dozer
So a little progress has happened since last time...
One side of the track links are complete ( awaiting metal to machine pads). these take so long !
Had some stock delivered for the idler wheel and roller wheels. will start machining over the next few weeks to size
Started the idler wheel …
Quick question on electrics if anyone can help ?…
so I am planning on using a 24v battery, running 24 volt motors which is easy as the sabretooth controller can take that voltage but what happens if I want to use a Premacon 12v hydro pump in the system - does anyone know what I need to reduce the volts for the pump?
should have some more pics of the track carrages over the next few weeks once the metal turns up
Cheers
Rob
