Old 05-28-2020, 09:27 AM
Default Re: Pump gear what if?
It would be very difficult to flow test the pump in the machine, especially since the radio mixes the valve opening and motor on. Best to remove the pump/motor and wire directly to power source but that may not be easy to do. Possible that a valve is opening or stuck open that returns oil to the tank? That would account for low flow/pressure going to the cylinders.
