Old 05-30-2020, 12:20 PM
Default Re: I think I need a bec!
Everything else in the model is stock, as in chinese electronics? ...probably BEC. Most ecs only put out 1amp at the most.
The link above, the Castle Creations 10amp BEC is cheap & will probably solve your problems.
Yes Joe all stock. The original owner added a separate BEC to control the lights.
I unhooked the lights for now and used the BEC to power the rx. I'll have to look at it and see what size or make it is.
There are some other issues with the hydraulic valve not responding correctly. Maybe that is part of the culprit because if the servos have some draw on the system ; that may lower the voltage slightly enough to have the two escs run continuously. I keep the pump on a slow idle too. Helps with the response time on the sticks but that runs away too sometimes.
