Old 09-20-2020, 03:46 PM
Default Re: Huina servos disassembly
From the amazon pics, they look like probably Tapered Pins?
So support the shaft with something that leaves room for the pin to come out. Small side of pin facing up, select a pin-punch just small enough to fit, tap out pin with small hammer. It should start moving after a couple taps.
If it's just a Roll Pin, or a Straight Pin you won't need to determine a small end on it, it can go out either way
