Old 10-20-2020, 06:42 AM
Benni Benni is offline
Benni is on a distinguished road
Default Re: 3D print question
I've found a few things on thingiverse.com, 1/14 and 1/10 scale and there is no problem re-scaling them in the slicer software, I use Repetier simply because is was on the SD card that came with the printer.
If you do try to design your own stuff (fusion 360 or sketchup) I recommend starting small/simple and print test pieces.
Not draw a whole/half a body and then discover what your printer can and can't do, that's the mistake I did...
