Old 04-01-2022, 07:35 PM
Default Re: Time for a rebuild
Thanks ddmckee,
Scale wise the WPL axles are a little small for the Bruder's, if you can get past that and use 5mm to 12mm hex adapters and then use bigger wheels and tires they might work....But your right they are a perfect fit for this size Tonka/Nylint/Buddy L even the Ertl Big Farm
The body of the cab was straight just had a lot of play wear, I just stripped it and repainted...The bed on the other hand was pretty rusty and was played with pretty hard through the years. It was considered a "custom project" piece meaning it had lost most of it's collector value...but the outside was straight and ...it's a toy after all that I'm taking to the dirt...
