Old 10-11-2022, 01:56 PM
Default Re: Nylint michigan crane conversion, hopefully
Frizzen:
I've got a set of WPL plastic axles that I bought to see if they'd look right under a Bruder, along with the aluminum wheels and the tires. They were too small, a 5-6mm difference in OD makes a HUGE difference. Anyway, I've got the steer axle, the center axle and the rear axle. The plastic axles and the metal axles will have the same dimensions. If you need any dimensions let me know and I'll get them for you.
Don
