Old 02-11-2023, 02:42 PM
Default Re: Ford Custom Deluxe station wagon - 1950 Woody
Apparently if you add 'a bunch' of weight to a donor rc car, then don't change gear ratios or motor, still leave the motor wired backwards to the Esc, and don't keep up on cycling your battery pack... it's just not gonna want to run in Forward when you finally do take it to an rc meet.
I finally pulled the motor pod back out and swapped polarity on the motor so now the higher amp side feeds driving forward. It probably really needs a higher torque motor, or better esc, or even just a resistor in series, but i'm probably not going to do that.
Surfers don't have extra money dude
For totally no reason at all, and nothing to do with rental trucks. Totally not anything like a 16' TC or 17' EL moving van.
Wpl driveshaft carrier bearing
https://cults3d.com/en/3d-model/gadg...ong-wheelbases
Ford truck grilles by year
https://www.cjponyparts.com/resource...0-grille-guide
Tonka ford semi uses a 1953 grille
Chevy squarebody grilles by year
https://www.cjponyparts.com/resource...fication-guide
Nylint chevy pickup uses a 1973-74 grille
The 4wd with 1 ton carrying frame truck is a K30
Nylint made many versions of Uhaul trailers in
Covered single axle round fender, no fender, square fender.
Covered double axle no fender, square fender.
Open no fender, square fender
Nylint Thoroughbred Farms tandem bumper-pull seems to be a Stidham horse trailer
Gasoline Alley Toy Parts may give 10% promo codes to a BESTCUSTOMER
