Old 09-11-2023, 01:28 PM
Default Re: Cable Shovel Build
If the cab wall around that door has a constant radius, it shouldn't be that hard to match that bend radius with the door and 2 tracks. Maybe look as using some Brass sheet and square tube, could even make a steel door if you feel hardcore.
But then i went back to look at pics, and that door isn't going to travel much forward before it needs corner removed, and aft looks like it goes flat to radius?
Maybe punch the charge jack down through the cab floor somewhere that overhangs the base?
