Old 12-18-2023, 12:35 PM
Default Re: Michigan T-24 project
I angled things and trimmed plastic off stuff and sanded and grind-ed on the slew motor case... I angled stuff there was just no other place to put it then right in the center... Which by the way has a "hump" pressed into the metal on the bottom of the toy so that had to be cut out so the slew motor would fit flat... Luckily so far this has been the only real issue I've run into....
And your right this build is coming along way faster and way smoother then I thought... so far...
