Old 01-30-2011, 11:09 AM
D8R D8R is offline
Default Re: D8R +463 in 1/5,6
Thanks for comments, Guess I can contine add details, you guys like that
got some time free this weekend, made the yoke and holder for front cylinders. The holder turned out to be a little nightmare to do, they are supposed to be quite thin, did figure out to make a ring with an axle inside. Those to components was supposed to be brazed together and Problem again with brazing, don´t know what but ended up working a lot before I finaly got them done. The ring is only 2mm thick and the remaning parts from axle (when center part is milled away) will take all force from cylinders, that´s why I needed to have them brazed.
Test mounted with cylinder tubes, tape only to hold tube in place.
Have a nice sunday!
Dan
