Old 02-01-2011, 10:42 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: hand made custom wheels
Originally Posted by sneaky-pete View Post
Mine are on there just for show right now.
I am going to use them on a truck I am building.
The trailer hubs Steve makes are perfect.
If you put six small bolt heads around the cap,and paint the center red it
looks real good
Troy, yes they would look perfect but those bolts that hold those hub caps on are 1/2" I don't think you can find a nut that small let alone a bolt or screw. But what would work is one of the rivets that we use on the cabs. I think they are the 1.2mm ones. maybe just a little smaller. then just drill a small hole and glue the rivet in.
As for the filler cap, just get Steve to make the cap inside the window when he cuts the window out. Not sure if that can be done but rather than machine the whole area out like the ones in the picture just leave the little cap, maybe say 2mm round right in the center. I have not a clue if this is doable or what it would take to do it, just a thought.
They look great just like they are Steve, don't get me wrong. Just my need for perfection, or as it's called in the RR model hobby... I suffer from being a "rivet counter".... Makes life a Bi@#h some times.
-Mike
Mike "DREAMWEAVER" Johnson
