Old 02-09-2011, 08:20 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: What mill to buy
After 25 years of running various CNC machines, I would get the biggest you have room for. I have 2 Sherline mills, 1 Taig mill, a Micromark larger mill, 2 Sherline lathes, and a South Bend lathe. The Sherlines have been worth every penny they cost. The Taig has been a BIG dissappoint for me- not as accurate as I thought it should/would be. The S. Bend lathe is a pre-WWII hobbyist machine with split bushings in the headstock not bearings but it is rather large- 9"X48". One of the Sherline mills is a CNC conversion by Microkenetics- I do not reccomend this company at all. I am presently changing it over to the Sherline system. Granted the Sherlines are smaller than a lot of the other machines and lighter by far. They will do the job if you are concious of their limitations. If I had to do everything all over again without the space limitations I have, I would get a floor model CNC mill and lathe.
Hope this helps?!?!?!
Lynn
