Old 02-16-2011, 01:35 PM
Default Re: Controlling several models at once... how to?
Originally Posted by carp View Post
14mz thats a nice radio, in theory you could have both models switched on and just switch between model memorys,
Thanks, I love this radio, it's so easy to use and has infinite possibilities.
That's what I was hoping for, but have been told that every rx that is bound to the radio and powered up will effectively be listening for radio inputs, regardless of what model memory I have selected on the radio.. although I think you can cheat it, buy changing the radio settings from FASST to normal, but I need to do a little reading on that.
However, you are 100% correct for a spektrum radio setup, they have a feature called model memory, so only the rx you bound in that model memory will function.
However, I have been surfy today and found this... seems like the exact device I need. http://translate.google.co.uk/translate?hl=en&sl=de&u=http://www.flymotec.de/product_info.php/info/p46_modell-wahlschalter.html&ei=NA9cTcnqAdGHhQeGk9ntDw&sa=X&o i=translate&ct=result&resnum=1&ved=0CCMQ7gEwAA&pre v=/search%3Fq%3Dcti%2Bmodell%2Bwahlschalter%26hl%3Den %26client%3Dfirefox-a%26hs%3DP46%26rls%3Dorg.mozilla:en-USfficial%26prmd%3Divnsfd
Elliot.
