Old 02-22-2011, 11:41 AM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: Extended Knight
Originally Posted by Roadmasters View Post
If i didnt seal off the top half of the sleeper there would be more. If you really want me to do yours i would, i like wiring. I just drilled a hole so the led sits tightly in there and when im ready ill glue them in with some silicon or super glue.
What size drill bit did you use for the 3mm LED's, I have found one that is just a bit to tight, and the next size up is to big. I would imagine if necessary one could use the former and then a small reamer to get them to size.
And no I was just pulling your leg. I have no problem wiring.
~Mike~
Mike "DREAMWEAVER" Johnson
