Old 03-14-2011, 12:54 AM
Default Re: Some real old & some real new
Very cool, Fred. Kind of similar to what the Wedico 3 speeds use. They have an output shaft on the transmission also, for PTO work, and the axles can be disconnected by the differential, so the transmission doesn't have a neutral.
I'm curious if you can drive the truck forward with the PTO raising the box, or if you have to choose one function or the other? Either way, a working PTO is very neat, even if you have to be stopped to run the PTO. Nice job.
