Old 04-14-2011, 01:42 PM
modelman modelman is offline
Default Re: Cat 777D Mining Truck
I got the hand rails and ladders made.These pcs. did not turn out as good as I wanted but I knew this was going to be a problem for me. Some things I cannot do with bad eyesight. In my mind I am a perfectionist but with bad vision perfect is only a dream..
I scaled from the Norscot model to get the height of the hand rails so I don't know if this is correct or not-
These ladders are only 2" tall X 3/4" wide.
These parts will not be attached until all the body work is done since they would be too hard to work around. I will try to build the screw drive next so we will see how that goes.
