Old 04-27-2011, 11:11 PM
tfmacz tfmacz is offline
tfmacz is on a distinguished road
Default Re: Hydraulic Pump Motor Control Options
Hi Iain
is is possible you could share the pic hex files for both the H-Bridge drive pics and the pump switch pic.
I can program pic's and a couple local guys would like to play with you design.
Thanks for sharing
Originally Posted by iaindunn View Post
Hi again. just thought I would include a pic of my control board amd circuit diagram. This has 3 speed controllers and the hydraulic pump switch on it. The pump switch is good to about 4 amps without heatsink but can go up to 12 amps with a heatsink.
The pump switch is the bottom PIC chip. Not sure if the diagram will be big enough as an attachment.
