Old 04-28-2011, 09:59 PM
tfmacz tfmacz is offline
tfmacz is on a distinguished road
Default Re: Hydraulic Pump Motor Control Options
I am looking to take some shortcuts to start with. So If you have the .hex binary files would save me some time initially. I use Eagle for pcb design and I make prototype pcb's on a small cnc mill built for the purpose.
I have your schematic diagram, could you post an image of the copper side of the pcb? It will save me some layout time.
I don't currently have mplab installed anywhere.
Looks like I will have to rebuild my development box.
Thanks for all your help.
Ted
Originally Posted by iaindunn View Post
Would you prefer the assembler as you then play around with it in mplab ?
I have posted the assembler for the pump switch above:
Below is the speed control based on microchips simple esc desigen but rewritten to give forward and reverse. The track motor controls are on one 12f675 and are simply forward and reverse for both run off toggle switches on my trasnmitter. I did do a 2 speed version but didn't gain much from it:
Any questions just ask.
Iain
