Old 05-17-2011, 01:02 PM
Juganought Juganought is offline
Juganought is on a distinguished road
Default Re: Scania R620 Stretched ....first-pitch
Originally Posted by fhhhstix View Post
I use a 55turn and 4:1 gear reduction with stock pinion. Other members us 55turn and a 6 tooth pinion which is about the same as the 4:1 and stock pinion. I was using the Novak Rooster crawler,fifty five combo but since the quit making the fifty five they now use the Terra crawl 55 in the combo but the Terra crawl is a sealed bushing motor so now I guess I will use the integy 55 with the Rooster crawler ESC.
Travis
@Travis: It appears that Novak has discontinued the familiar 45 and 55 turn. This seems to be its replacement http://www.shopatron.com/products/pr...35X7/135.0.1.1 I use the Novak 55 turn and 6 tooth pinion, so far the results are good, I also have a Holmes 65 turn and 6 tooth, so much torque.....Thanks to Tamiya Cowboy, saved some pounds on Gru's :-)
Dont mess with ma trucks
