Old 09-01-2010, 09:39 PM
Default Re: Helical gear set for tamiya semi trans?
Scott , if I remember right from a conversation with joe when I started He never had an issue . After building my first 1 , It seems you have to wear the bushings out before the gears start to fail and make sure you keep it lubricated well . also the brass will bind faster than the plastic if not greased well .
