Old 01-03-2012, 03:15 AM
Default Re: Azonic Hitachi 470/Bell B50D
Your cyls starting to drip? My stick cyl is seeping a little bit, but I think it's mostly just when digging hard ground - run at max press constantly, don't see any pooling in easy digging.
Joe, can't remember if you cylinders came built or not? But it they are the same as mine, there are 6 bolts on the end, this removes the end cap, inside are two tiny rubber o rings acting as scrapper seals. I assume with all your digging and high pressure you're worn them out...?
Mine even came with spares..
Hope that helps?
Elliot.
