Old 01-06-2012, 02:07 AM
mpe's Avatar
mpe mpe is offline
mpe is on a distinguished road
Default Re: MPE – 24M Motor Grader Build
Originally Posted by 9W Monighan View Post
How are the two outer plates joined to the center (3/4''plates?) Not the raised area around the flanges. I can't see if you bolted or pinned because the surface was sanded.
Ahh great question 9W. They are machined out of one solid chunk of aluminum with some amazing machining.
Well not really from one chunk. Actually the entire assembly has 5 parts and a lot of M2 screws. I had designed these parts so the screws are on the bottom so they would not be visible.
Take a look...
