Old 01-06-2012, 12:14 PM
Default Re: Pete 367 in brass
Is the cab floor or the sill plate of the cab in the way, or something, that you can't push the pin in from the bottom? You might not have a choice but to solder the hinge onto the cab and door, after the pin is in place. Unless you build the hinge first, and then bolt it to the door.
