Thread: Lathe Motor?
Old 01-23-2012, 11:47 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: Lathe Motor?
A lathe motor is basically a modified motor with more turns of wire instead of less turns which most modified motors have for higher rpms. All of the added stuff on the end of the motor is so you can 'tune' the motor to your desired rpm by changing the brushes and brush springs.
LYNN
