Old 01-27-2012, 09:24 PM
Default Re: Day Cab Work Truck by Izzy
Originally Posted by CustomRCmodels View Post
Now that is interesting .. I just looked at that too …
Guess you are right , that could be it , since by the dimensions they list there it should fit/work .
Good find ! Must be a new item …guess I need to get me a set and check it out .
I am wondering how it’s done , if it can fall apart when you excide these 50mm length ?
What irritates me on the UK-trucker photo is that the u-joints are lined up so strange ,
not even , not 90 degrees offset , just a few degrees offset
You are correct they (yolk's) need to be lined up or a vibration problem will result, I'm guesing it's just off by 1 spline. Good eye to catch that!
Cheer's, Neil.
