Old 02-03-2012, 09:36 PM
Default Re: Driven front axle options?
Originally Posted by gun View Post
can some one tell me what to use on the input shaft for an axial trans. that im using for a transfer case to go to 5mm so i can build my drive shafts? the shaft on the axial tranny is small and threaded i guess i should cut it off and grind a flat end on it?
Just like you said Shane cut it off and grind a flat.
Originally Posted by Snochaser View Post
What mud flap holders was Freddy using in the above picture, anyone know?
Those are stock king Hauler mud flap brackets with springs so they work like the real mud flap brackets.
Travis
