Old 02-28-2012, 07:25 AM
Brel's Avatar
Brel Brel is offline
Default Re: wiring servonaut
A English version of Günther's wiring diagram
http://www.servonaut.de/shop/media/p...1295631318.pdf
I use just the BMA pump module in my tracked loader with a dual ESC and Hook lift skip truck with a Tamiya MFC- 01
to get the pump to run for a set time after the hydraulics have stopped
you put the jumper on pins CD turn on the power and the after the time you want the pump to run for, put the jumper on pins AB, you do not need to have the TX turned on at this stage and when you start the model turn on the TX first and then the model and this sets up the BMA controller, otherwise it sets to the default time
I have got the run time after the sticks have been released to about 1.25 seconds
