Thread: Volvo EC300D
Old 03-26-2012, 07:56 AM
steamer's Avatar
steamer steamer is offline
Default Re: Volvo EC300D
Reg, the only suggestion that I would make is to change from the round actuators on the spools to leavers. If you stagger the height of the arms then you could run every other spool with two servos on each side instead of direct drive. Then make the arms as long as needed to get the torque to move the valves. Hope this makes sense.
Rob
