Thread: Volvo EC300D
Old 03-26-2012, 03:14 PM
Default Re: Volvo EC300D
Reg , the Robbe valve is exactly what your doing . I'm thinking you have more pressure then you need . do you have a pressure relief valve in somewhere ? If not , put 1 on the supply circuit after the valve . come out where the plug is ( assuming thats the supply side of your valve ) I haven't got to play with the stuff from Richard yet , but I plan to make a solid base for the valves much like the verio setup . they bring the supply from the pump through the valve into a pressure relief valve of some sort ( needle valve I think ) .
