Thread: Volvo EC300D
Old 03-26-2012, 04:03 PM
Default Re: Volvo EC300D
Originally Posted by ihbuilder View Post
Reg , the Robbe valve is exactly what your doing . I'm thinking you have more pressure then you need . do you have a pressure relief valve in somewhere ? If not , put 1 on the supply circuit after the valve . come out where the plug is ( assuming thats the supply side of your valve ) I haven't got to play with the stuff from Richard yet , but I plan to make a solid base for the valves much like the verio setup . they bring the supply from the pump through the valve into a pressure relief valve of some sort ( needle valve I think ) .
Thats interesting to know that they are the same. I do have a relief valve and it's set at about 28 bar. At 20 bar this machine doesn't have a lot of power but the valves do turn much easier. I would like to be able to dig firm ground with it so I think 25-30 bar is necessary. Do you know the diameter of the valve?
Thanks Reg
