Old 04-01-2012, 06:15 PM
Stepside's Avatar
Stepside Stepside is offline
Super Moderator
Default Re: Aeromax Daycab Dump 6x6 (Update: 4/01)
Originally Posted by fhhhstix View Post
Looks good Rod. I would not get to excited about fastening the bed together before you get the screw drive built or the bed may sit to high on the truck.
Tks Travis! I actually have the box sitting on that 5/8" channel that we talked about the other day, so I'm sitting at the proper height. Once I get the box built and hinged, I'll work on the screw drive... under your close supervision!
Originally Posted by Bsorenson79 View Post
Awsome build!! I'm always looking forward to your build up dates. I was wondering what gauge aluminum are you using for the dump body?
tks bill! the aluminum is .025" thick, great to work with. When I built my dump trailer (4 years ago!!! wow!) I used all 1/16" material for the sides and 1/8" thick piece for the floor!!! It weighs in at 17 pounds empty! I'm going to build a new dump trailer after this dump truck project is wrapped up.
Nice start on the box, Rod. At first I thought it was one piece, and I was going to ask how you got the bends so close together, at the floor. I never saw a box and pan brake, or a brake press that could do something so tight, but then I saw the sides are separate pieces and you'll make the floor separate too? That's cool.
Thanks Nathan. Right now I have 3 aluminum pieces on the bed: 2 sides and a central tub, a U piece to tie it all together. I'm excited to get more done and make it look like more than a pile of sheetmetal!
East Coast Mini Truckers
