Old 04-25-2012, 10:06 AM
scalelover's Avatar
Default Re: Machinist opinions
Originally Posted by Joat View Post
Read up at mini-lathe.com
I love my grizzly 7x14 lathe, once you do a few tweaks it's a well worth the money, I have an adjustable backing plate for my chuck and can get .0005 or less in accuracy,not bad for a $500 lathe!!!!!!!
I also have a LMS mini mill, like it very much
Read up on mini-lathe.com Frank has a world of good info there.
I will check the site and do some more research before I make a purchase. I do appreciate all the info you guys have given me on this.
On another thought if I went a bit bigger than the tabletop what would you recommend. I have a decent amount of room available in my hobby room, but I also have an old root cellar that I was thinking of converting to my machine shop anyway, if that's the case then I'll have quite a hit more room. In there it's roughly 8x12 or 14 and I can build whatever I need as far as benches shelves framework etc etc etc. so this way may be a better option anyway. Only downside is I would have to do a but of prep work to area, like add some insulation and probably false walls just to keep the temp a bit more stable in there. But again not a huge deal if I have too
--Dan
