Old 04-30-2012, 10:58 AM
dabears's Avatar
dabears dabears is offline
Default Re: My Dremel finally Died for good!!!!!
I'll get picks up asap when I get back home. It's not the brushes, it's an older off brand "dremel" tool. It has a brushless motor in it. In between the motor and the shaft there is a thick spring bent to suit in notches on both ends. Without it the motor works fine but the shaft will not spin. It's chit when you hit a snap the spring takes the brunt of it.
