Thread: Utility Truck
Old 07-15-2012, 07:35 PM
cyanide cyanide is offline
cyanide is on a distinguished road
Default Re: Utility Truck
Set up the hoop mounts properly and reset the tranny, then finally started on the skin!
Made from old computer case, hence the max payne sticker on it. I find computer cases great because the sheet steel quite often has nice folds and lips pressed into them that can be used to inset etc. I find the computer cases are more rust resistaint than the other standard mild sheet steel we use also.
