Old 07-17-2012, 03:20 PM
SmallHaul's Avatar
Default Re: My first Tonka dump truck
Originally Posted by 69tony12 View Post
I know its an old topic, im converting a bruder sprinter van and i have some wedico leaf springs, the springs have 2 holes (the axle is a bit wider than the holes) how do you suggest i put them on? and also how did you do it on these, i can see you have a screw on the axle, how did you put it on it
Thannks alot
Unless you are using mini giant axles it wouldn't help to explain how I mount the leaf springs on them because they have mounting points with balls (for the suspension links) and I mount off of them.
You should make a thread up for your sprinter van and post pics of what you have to work with, then it would be easier to give you ideas on what to do.
Good luck!
Scott
"No load is too Small"
