Old 08-24-2012, 10:03 PM
Snochaser's Avatar
Default Re: Snochaser's Construction Co. Builds
I recieved one response back from ScaleART pretty much saying "our stuff doesn't have problems, sorry about your luck."
I hope to hear back a little more. I went and found some servos that will fit. I noticed the valve body had a sticky spot to it, so I rotated the valve around to an easily moved position. All is working with the hydros now. Fingers are crossed!
Next step is to contact Brixil electronics to figure out the operation of their pump control unit.
Ben
, you will not be forgotten.
R.I.P. FGD
Work Hard, Play Hard!
Never Forget- 343
