Old 08-25-2012, 11:13 PM
apfubar apfubar is offline
Default Re: Snochaser's Construction Co. Builds
Ben,
It does look good...
Which hoses did you blow? From the pump to the valve block or one of the lines to the rams? Just curious.
On the servos, as previously suggested also check the end points. On my excavator I check them every now and then (every couple of months) just to ensure they aren't hitting the stops and damaging the valves or themselves.
It will be interesting to hear how you go with Brixl stuff.
Cheers,
AP
