Old 08-31-2012, 12:37 AM
PROBUILDER1964 PROBUILDER1964 is offline
Banned
PROBUILDER1964 is on a distinguished road
Default Re: optimus prime transformers
the problem sometimes with bondo ...guys it can eat or screw up the plastic ! i like to use a two part "epoxy sculpt" you just mix equal parts of the putty together smear it on...and it even can be fine smoothed with water ! once it dries to a super rock hard finish...you can sand it out to what you want. It never shrinks or hurts the plastic your working with ! once you try it and see how it works...you will never use anything else ! Also that green putty can bleed through your paint and you will have a dark shadow there all the time !
